oil pan ?
Old Nov 28, 2009 | 07:24 PM
tomsws6's Avatar
oil pan ?
Ok so if a pickup tube falls off then do you need a new oil pan or a new oil pump or what? i know stupid ? but.......
Old Nov 28, 2009 | 08:32 PM
chevyowner02's Avatar
You will need to pull the oilpan off and the oil pump reatach the pickup tube and have it tach welded so it dont happen again. But if its a old pump might not be a bad ideal to replace it while you are in there.
Old Nov 28, 2009 | 09:51 PM
tomsws6's Avatar
so the pickup tube is attached to the oil pump?
Old Nov 28, 2009 | 09:55 PM
maverickmk's Avatar
Yes, unless it falls off
Old Nov 28, 2009 | 10:43 PM
tomsws6's Avatar
smart a$$
Old Nov 29, 2009 | 12:52 AM
camaroz28383's Avatar
if the pump has not been replaced before I would replace it since you have it out anyway and its only like 50-60 bucks for a new one. Its just added security
Old Nov 30, 2009 | 06:25 PM
maverickmk's Avatar
smart a$$
Yeah, sorry that was kind of a cheap shot. The oil pump & pick up are separate parts purchased separately. If you buy a new pump as stated above buy a new pick up as well. A stock pump is fine you don't need a high volume pump.
Old Nov 30, 2009 | 06:57 PM
JAKEJR's Avatar
There are oil pumps available that have the pickup already permanently mounted to the pump, you just have to search a catalog like Summit or JEGS to find them. Also there are pumps that have pick-up that bolts on, and some with braces eliminating the need for brazing or welding. I've even seen pickups that screw on also eliminating B or W.
If you go with a new pump, check out those that have pressure equalizing grooves on the cap and inside the pump body. Those grooves eliminate pump gear chatter resulting in smoother oil flow into and out of the pump. It's an 'Ole Racer's' trick now used by Moroso and perhaps others in their high quality pumps. Be sure that the pump has been pressure tested, it should be listed in the ad.
Also,you just have to be sure that the pickup distance to the bottom of the oil pan is correct. That's critical!
Jake
West Point ROCKS!
Old Dec 1, 2009 | 03:33 PM
tomsws6's Avatar
na it was a good one. thanks guys
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
