oil pan
Old Nov 5, 2008 | 10:13 AM
z28camaro1090's Avatar
oil pan
I wanted to drop my oil pan and change the oil pump and clean out down there while i was at it. someone told me i wouldnt be able to get teh pan off while the engine was still in the car is this true? do u guys recommend this or no?
Old Nov 5, 2008 | 11:03 AM
camarobird92's Avatar
Yes it can be done, I believe, if you take both motor mounts loose and lift the motor a bit.
Old Nov 5, 2008 | 01:20 PM
seawolf06's Avatar
You will definitely have to lift the motor some. It's better to use a hoist, but some have risked it and used the balancer.
Old Nov 5, 2008 | 02:20 PM
Green96Z's Avatar
I had both motor mounts out and the engine jacked up to change my oil pan gasket, and there was no way that pan was coming out. You will probably have to drop the crossmember a little.
Old Nov 5, 2008 | 05:03 PM
alright lol.. im not in the mood for any pains in my *** this week lol.. i already gotta change control arms.. which i cant find a decent price on
Old Feb 24, 2009 | 10:50 PM
OPies57's Avatar
if you have long tubes they hit the body before you have enough clearance you need to drop the k member
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
