oil light sensor
Old Jul 29, 2003 | 03:56 PM
limige's Avatar
oil light sensor
i've got a 94 and the low oil light has been on all year, there's plenty of oil, it's on most of the time but goes off occaisonally.
what triggers the low oil light? is it a seperate sensor? if so where exactly is it located? when i did my clutch i found a harness with no home, someone had jumped the wires, i'm wondering if they bypassed the low oil light, it's not the skp shift or the reverse silinoid, those i disconnected
Old Jul 29, 2003 | 04:56 PM
Low oil sensor
Brn and blk/wht wires going to it.
Old Jul 29, 2003 | 05:08 PM
notstock4long's Avatar
Most of the sensr plugs on the car are the same. This one is on the bottom of the oil pan, and if you pull the sensor you will lose your oil. But if your plug is missing, just go to the junkyard and take a bunch of them, one will fit. Then just solder the wires together
Old Jul 29, 2003 | 05:47 PM
limige's Avatar
thanks guys that's it!!!!!!!!!!!!!!
SHOEBOX YOU DA MAN!
some idiot before me pulled the sensor, and jumped the wires, my oil pan has a huge plug there!!!
Old Jul 29, 2003 | 06:50 PM
SHOEBOX YOU DA MAN!
Well, it is good to have, but is marginally a "needed item", since most cars don't have one. If mine was already bypassed, I am not sure I would go to the trouble to hook it up. No problem in hooking it back up, though. Just a little more insurance.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
MattFick
Feb 15, 2015 10:16 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
