oil leak HELP!
oil leak HELP!
ok there is oil leakin form somewhere on the driver side motor That is wat has been messing up my 02 senor. The connceter is filled with oil. first question is can i just clean the conntor or do i have to get a new 02 senor again!!!!2nd? any possible idears where the damm oil is comming from. I mean i see oil on the side of the motor but i cant trace it
You can clean the connector. No oil should be getting inside the connection. Those are weather-pack connectors meant to keep water out. The oil leak could be the infamous intake leak at the rear of the intake. Very common on LT1s.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
