Oil Filter Adapter, ever replaced one?
Old Feb 2, 2005 | 12:31 PM
vette40th's Avatar
I need a oil filter adapter for my LT1 block. GM parts direct said there are 2, one with plug/adapter/spring and valve, and the other part number is adapter only. I currently have the Vette adapter in the block, which is an offset adapter , which allows a smaller filter to clear the catalytic converter on a stock LT1, as the cats are huge.
Just curious if anyone has replaced theres, or taken theres off when they rebuilt there blocks, and know what the spring/valve and plug are for.
Old Feb 2, 2005 | 01:20 PM
Z28SORR's Avatar
Re: Oil Filter Adapter, ever replaced one?
Yes, a couple on the Vette. The spring/valve is the oil filter bypass valve and the only type I've seen.
Old Feb 2, 2005 | 01:26 PM
vette40th's Avatar
Any gaskets needed, or is the gasket on the filter housing all you need. Is it sailor proof, ie simple to do?
Old Feb 2, 2005 | 01:35 PM
vette40th's Avatar
You removed your adapter? Did you have the smaller filter on your TA? Or was this on a Vette?
HectorM52
Jul 30, 2017 11:46 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
