Oil dipstick tube problems!!!
Old Jun 2, 2004 | 06:29 AM
Got-LT1?'s Avatar
I forgot to mention this in my last post, but I was installing my oil dipstick tube after the headers were in, and it was being a real PITA so a friend and I were really kinda forcing it and all the sudden it just kinda slipped in and became really loose. I thought maybe i broke the tube inside the block but that wasn't the case... I pulled the tube almost all the way out and it seemed to be in one piece... My concern is; does the tube fit in some sort of sleeve that sits in that hole that I mayebe forced out and into the oil pan cause that would suck so much!!! Does anyone know what this could be, or did i just bend the tube just right so that it fits perfect now?
any advice would be helpfull, thanks
Old Jun 2, 2004 | 07:29 AM
pat97SS's Avatar
The stock tube has a "ridge" that sits on the top of of the block. Did you break that little ridge off? I reused my old tube and it did feel somewhat loose compared to how hard it was to get out. The bolt will keep it in and I used a little permatex where the tube goes into the block. No problems yet. However, I did not have to force mine in. It took a while to bend it how I wanted it and it went in easily.
Old Jun 2, 2004 | 08:18 AM
AdamZ1LE28's Avatar
Dont want to be a hijacker, but do you have to take the dipstick out to install Pacesetter LT's? I've heard a lot of people doing this but I also heard you only need to remove the valve covers, starter, plugs and alternator with the Pacesetters. Anyone know? Thanks!
Old Jun 2, 2004 | 09:46 AM
pat97SS's Avatar
I do not know about Pacesetters, but I did it with AS&Ms installed. I would think you have to, to see where the dipstick tube will need to go. I know this really did not answer your question. Sorry
Old Jun 2, 2004 | 11:32 AM
Got-LT1?'s Avatar
Hmm, i guess that makes me feel better, so there isn't any sleeve that i punched down into the oil pan... I was worried i was gonna have to pull the pan...
Thanks guys
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
