Oil dipstick tube problems!!!
I forgot to mention this in my last post, but I was installing my oil dipstick tube after the headers were in, and it was being a real PITA so a friend and I were really kinda forcing it and all the sudden it just kinda slipped in and became really loose. I thought maybe i broke the tube inside the block but that wasn't the case... I pulled the tube almost all the way out and it seemed to be in one piece... My concern is; does the tube fit in some sort of sleeve that sits in that hole that I mayebe forced out and into the oil pan
cause that would suck so much!!! Does anyone know what this could be, or did i just bend the tube just right so that it fits perfect now?
any advice would be helpfull, thanks
cause that would suck so much!!! Does anyone know what this could be, or did i just bend the tube just right so that it fits perfect now?any advice would be helpfull, thanks
The stock tube has a "ridge" that sits on the top of of the block. Did you break that little ridge off? I reused my old tube and it did feel somewhat loose compared to how hard it was to get out. The bolt will keep it in and I used a little permatex where the tube goes into the block. No problems yet. However, I did not have to force mine in. It took a while to bend it how I wanted it and it went in easily.
Dont want to be a hijacker, but do you have to take the dipstick out to install Pacesetter LT's? I've heard a lot of people doing this but I also heard you only need to remove the valve covers, starter, plugs and alternator with the Pacesetters. Anyone know? Thanks!
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
