Oil cooler removal help...
Old Mar 9, 2007 | 09:19 PM
wrd1972's Avatar
I have removed the oil cooler from my LT1. I intended to simply connect a hose from the radiator to th water pump in place of where the cooler was, but the radiator side is 5/8" and the water pump side is closer to 3/4" or so.
Where can I get a step-up fitting or does someone have another solution to this problem?
Old Mar 9, 2007 | 09:32 PM
You just by the bypass hose that every other f-body LT1 uses without the oil cooler.
Old Mar 9, 2007 | 09:47 PM
OBE1 95Z28's Avatar
You can also cap off those connections; no need to connect them. I ran my car that way for 4 years with no change to the cooling system.
Old Mar 9, 2007 | 09:51 PM
wrd1972's Avatar
Is this bypass hose a GM part or can I get it at any parts house
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
