Oil cooler removal help...
I have removed the oil cooler from my LT1. I intended to simply connect a hose from the radiator to th water pump in place of where the cooler was, but the radiator side is 5/8" and the water pump side is closer to 3/4" or so.
Where can I get a step-up fitting or does someone have another solution to this problem?
Dylan Latshaw
Mar 21, 2015 09:48 AM
