Oil Cooler Removal
All you will need is the by-pass tube for the cooling system and some bolts from a hardware store in order for the filter adapter to be replaced onto the block. Other than that I dont think you will need anything else besides time.
Just went out and took a quick glance at it from the top of the motor. So i'll just need a hose from the waterpump to the radiator.
I assume taht the cooler part is sandwiched between the block and the filter?
And i cant see it really being effective if hot coolant is going through it?
Darth Xed
13
Jul 22, 2002 12:45 PM
