oil cooler question
Old Nov 16, 2006 | 11:05 AM
94_camm's Avatar
oil cooler question
How do i know if the oil cooler is on tight enough?
Old Nov 16, 2006 | 11:42 AM
BUBBA's Avatar
You delete it and you won't have to worry about it.JMHO
Old Nov 16, 2006 | 11:58 AM
udlose94z28's Avatar
Does it serve a big purpose? Mine is leaking where the weld is at on the end, i just took it off last night to take it to a local welder to have the leak fixed and welded up. If it dont make a difference, ill just shoot a line from the water pump to the radiator, block the holes up at the oil filter and call it done.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97 RedSS
Jun 10, 2003 07:58 PM
Camaro90RS
Jul 23, 2002 07:57 AM
