oil cooler adapter plate help~~
hello, i have a few questions ., maybe ya'll can help.
the engine is a 95 lt1, came from a 95 z28. i know that it had an oil cooler adapter on it bwfore i bought it, the previous owner kept it. well , when i went to put the oil filter on, it wouldn't fit on, i believe i bought an ac delco #454. ( i think that was the part#) i'm assuming that i need to go and buy the oil cooler adapter in order to get this filter on....is this right?
looking up at where the oil filter screws in, there is 2 metal things sticking down, looks like the would fit into the adapter plate.. is there a way that i can get an oil filter on here without the cooler adapter? if ya can get a schematic, that might help me to explain it better.. thanks
Originally posted by Spinner
Replace the two metal studs with GM part # 3951644 and you'll be fine. The oil cooler uses studs, without it, you need bolts
I use allen head's but don't remember the length.There is also a clearance issue with a regular cap screw.
.I also run the LONG filter as for earlier year model's,like the extra capacity.
gb95zconvert-
The original post says he don't have the adaptor,that the other owner kept it.So read the post before commenting
gb95zconvert-
Originally posted by 1racerdude
gb95zconvert-
gb95zconvert-
well, here's an update. after going back and forth to the dealer a few times, i have ordered the adapter plate WITHOUT the oil lines. i guess the make 2. now that i read the posts here, i'm going to go out and try to remove the "guide studs" holding that little piece on.... that is what's stopping the filter from spinning on.. if i can get to the store before they close tonight , i'll try and get some bolts that will hold in there instead of the studs..... and someone stated that regular hex head bolts have clearence problems? i would order that dealer part, but i need it by .....yesterday, i can't wait for shipping
thanks so much for your help guys, btw here's a pic of my project, it's much further along now, i'll get some new pic's soon.... you can see the nice BBK that was swiped from me in there too
FYI, there is no difference between the adapter for the cooler and the one without.
I have both and they are identical down to the GM part number cast into them. You can order the other adapter, but what you need are (2) 1/4 inch bolts.
Originally posted by djlunchbox
thanks, i guess the parts guy is clueless..(i hate that , it's his JOB to know this stuff...) i hope i can get some of those bolts tonight, so i can prime this baby first thing in the morning
