Oil after a cam swap
Old Jul 11, 2005 | 11:23 PM
ibanez6rg's Avatar
Is it normal to have small (really small) metal shavings in your oil? Not a whole lot just a few here and there.
Old Jul 12, 2005 | 01:24 AM
atljar's Avatar
Re: Oil after a cam swap
no, immediately drain it, and refill and re filter. I would run it for 5 min and then drain it again and repeat above. Then check it again.
Did you put in another cam?
Old Jul 12, 2005 | 01:29 AM
Will84's Avatar
Yes, it is normal to collect metal particles. That's why they sell magnetic drain plugs so that you can collect it and remove it at your oil change.
Old Jul 12, 2005 | 01:48 AM
atljar's Avatar
Visable metal shavings in your oil is not a good or normal condition. If you can see them, you have issues
Old Jul 12, 2005 | 04:46 AM
HungryT/A's Avatar
I've done a cam swap approx. 1000 miles ago, changed oil several times, but metal shavings never showed up, not even after the "30 min-2500 rmp" initial break-in...
Old Jul 12, 2005 | 07:02 PM
Will84's Avatar
Metal flakes big enough to see floating around???... no, that's not good. BUT... any one of you can swap your drain plug out for a magnetic one and you WILL have metal shaving stuck to it at your next oil change.
Old Jul 12, 2005 | 07:04 PM
turbo_Z's Avatar
Yeah like other have said I dont think you should be any visible metal shavings or flakes in the oil but if you have one of those magnetic drain plugs then you will always find small particals on it... normal wear and tear.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
