Ohhh the Humanity
Old May 24, 2006 | 08:08 AM
JOE96Z28SS's Avatar
Unhappy Ohhh the Humanity
Well I was in the Process of Installing my exhaust and interior on my car that I just had painted and a frame restoration. I was looking at my engine and noticed a freeze plug was missing this engine had ZERO miles since I had it stroked (383) It just had distilled water because it's in heated storage, It must have froze some time, HORRIBLE 5000 Bucks to have this engine built I was soooo close to getting done talk about 2 steps foreward 100 steps back So I guess I'm now hunting for an LT1 Block
Old May 24, 2006 | 08:16 AM
amean94ta's Avatar
Re: Ohhh the Humanity
not a definite! put a plug in and try it or if your that worried put the plug in and pressuer test it may just have pushed the plug out has happned to many guys i know and they were fine
Old May 24, 2006 | 11:51 AM
ulakovic22's Avatar
I agree, the plugs are supposed to pop out like that so your block doesn't get damaged in the case of a freeze. Also is your car stored somewhere and you are paying for heated storage or is it in your garage? If you are paying to have it in heated storage and your motor is damaged because it wasn't heated allowing it to freeze you should be entitled to a settlement for at least some of the damages if not all. Just my 0.02.
Old May 24, 2006 | 08:18 PM
JOE96Z28SS's Avatar
unfortunately their agreement states clearly that that's not the case and there is a 4 inch crack on the passenger side of the block, My engine shop said they may be able to fix it, , I guess I'll keep my fingers crossed
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
cmbob67
Parts Wanted
Feb 10, 2004 12:24 AM
