Odd Window Motor Question
Old Apr 8, 2003 | 03:59 PM
Ws6Envy's Avatar
ok...i replaced my pass. side window 1 month ago and worked perfect. Recently i noticed me driver side window going up little by little. The switch was bad and was making noise from under the steering colum. I replaced the drivers switch and the driver window goes up and down more consistantly...but still pauses. Since i replaced the drivers switch the pass. window wont move...and sometimes make a "machine gun" like sound (*dun dun dun dun dun dun dun dun dun*)
any ideas?
i know i have to replace my drivers side window motor
Old Apr 8, 2003 | 04:05 PM
Kris93/95Z28's Avatar
http://home.swbell.net/shoebox/windowmotor.html
This should help when you plan to install a new motor
Old Apr 8, 2003 | 04:08 PM
I would make sure that your connector on the back of the switch is not damaged or any wires loose within the connector.
Old Apr 8, 2003 | 04:27 PM
Ws6Envy's Avatar
on which connector....the drivers side is brand new...and the passenger side is broken and awaiting a new switch (broken one is still in the plug)
Old Apr 8, 2003 | 05:26 PM
The LH or RH switch/connections can affect operation of the RH motor.
Old Apr 8, 2003 | 05:38 PM
Ws6Envy's Avatar
thank you for the info...looks like i have a date with my soldering gun tomorrow.
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Nov 20, 2014 06:32 AM
Snoman73
Nov 17, 2014 07:22 PM
