Odb1 connector!
Odb1 connector!
I was given a cable for my lt1 edit setup. The cable is for the odb2 cable. can these be modified to fit. also i have a actron code scanner and it is for the 94 connector. Can i make this fit with my wires? Thank you
the port isnt really and OBD1/OBD2 thing. its a 93-94/95-97 thing. so you just have the older port but still OBD1. you needed to specify you have the 14-pin connector instead of the 16 when you bought the cable.
autoxr166
Sep 25, 2015 04:21 PM
