obdII timing cover
Old Apr 8, 2003 | 10:30 PM
whitetrashT/A's Avatar
obdII timing cover
I just bought a long block out of an obdI car and was wondering what I need to do as far as the timing cover goes. Noticed the CPS on my '96 motor that this one does not have. I don't want to swap the timing covers because with my gasket work, it'll probably leak when I'm done.
Any ideas?
Old Apr 8, 2003 | 11:21 PM
Don't know if it is possible to have the CPS programmed out of an OBD-II car. It is only used for detecting misfires and won't affect performance. Of course, it would cost you some $$ to have it done.
IMO, I would just swap the covers and be done with it. You must keep the reluctor ring and crank hub with the CPS timing cover.
Old Apr 9, 2003 | 06:42 PM
TimChiaretto's Avatar
Did the long block come with with a crank hub? I don't think you can use a 96-97 crank hub on an ODBI engine, they are different lengths.
Old Apr 9, 2003 | 11:09 PM
What do you recommend, obdI conversion?
Old Apr 9, 2003 | 11:25 PM
96z's Avatar
96z
You can delete the CPS via LT1 edit. This is what Im going to have to do with my double roller timing chain.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
