OBDII to OBDI PCM Conversion Questions!!
Old Jun 8, 2006 | 03:51 PM
Mike96z's Avatar
I have a 96 Z28 but I wanted to get an OBDI computer to run in it only when I'm racing. Then switch them back around when just driving around. The reason is I have OBDI Tuning software and OBDII Software is just too expensive so I just wanted to know what YR PCM Should I get 94 or 95 and what will be some problems or what will not be used on the OBDI system, as in my sensors? Thanks Mike
Old Jun 8, 2006 | 04:07 PM
sbs's Avatar
sbs
Re: OBDII to OBDI PCM Conversion Questions!!
http://madz28.com/9697.php
(see item #5)
Why would you swap the OBD2 back for the street?
Oh, and as far as the sensors differences - do a search.
Old Jun 8, 2006 | 04:18 PM
Mike96z's Avatar
The reason is I have OBDI Tuning software and OBDII Software is just too expensive................(QUOTE)
Seen it done before with no problems.
Old Jun 8, 2006 | 09:44 PM
96flame's Avatar
The OBDI doesn't have rear O2 sensors or Crank sensor and the Knock sensor is different resistance which is what is modified in the OBD1 conversion from MadZ28. Why would you switch back on the street? Just use the tuned OBDI and use the power you gain with the tune.
Old Jun 8, 2006 | 10:08 PM
Mike96z's Avatar
my rear o2's are deleted already and I have an x-pipe and I could tune the knock sensor or use an OBDI style on my car. Switching back because of inspection problems will arise.
Old Jun 8, 2006 | 10:10 PM
wrastler's Avatar
I swapped to OBD1 and there just isnt a point to switchin back and forth...I actually get better mileage after the swap...and all my gadgets n gizmos (cruise control, etc...) run fine.
Old Jun 8, 2006 | 11:19 PM
Mtrhds94Z's Avatar
May not be a lot of point to switching back and forth, but when due for smog/inspection if the car is OBDII it needs to be.. welll OBDII, not OBDI.. but I would only switch to go to smog/inspection.. not every week, etc..
Old Jun 9, 2006 | 12:01 AM
whitehooptie's Avatar
Program the knock sensor out and just plug the computer in. I did it on a buddies car. He has a 96 Z and I have a 94 Z. Mine was dead for a few years and he had a depressing dyno run. He had 241 to the ground with some rockers and exhaust, cold air and a couple of small things. Swapped the computer and he picked up 32rwhp to the ground.
Old Jun 9, 2006 | 11:16 AM
96flame's Avatar
If you get the conversion computer then your OBDII knock sensor will still work. He modifies the circuit inside the pcm case. Then switching back and forth is still possible.
Old Jun 9, 2006 | 12:54 PM
Mike96z's Avatar
Not sure what I'm doing now, the car just started missing etc. and stumbling really bad after I put some gas in it. Hope it isn't bad gas, DAMN ETHANOL
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
