OBDII to OBDI conversion (OBD2 OBD1)
Old Mar 2, 2004 | 11:25 AM
Hotwire's Avatar
Question OBDII to OBDI conversion (OBD2 OBD1)
I've searched all over the forum/web and cannot find a decent explanation of what needs to be done.
I'm not a stranger to the OBDI portion of it, did the swap in my S-10, know the wiring diagram about by heart, but what is involved with taking a OBDII to OBDI?
I've seen a post that said you change the knock sensor and plug in the obdi ecm?? is that it? what about the spare o2s? tranny wiring? ALDL?? Please, I need some info guys/gals.
Even if someone could send me a 96/97 ecm wiring diagram/pcm pinout, I would be grateful. I have a friend putting a 97 ss lt1 into a 197* el camino and wants to go obdI to simplify the install and get me to help w/ the tuning/programming.
thanks in advance.
Jeff
Old Mar 2, 2004 | 11:48 AM
Mikey97Z's Avatar
I did the swap in my '97. The only thing you'll need to do is correct the resistance to the knock sensor. I got my OBD1 PCM from PCM for Less, and he put the resistor inside the PCM housing so that it's a easy to swap the two different PCMs back and forth.
When you put an OBD1 in an OBD2 car, it will ignore the post-cat O2's and the crank position sensor.
Old Mar 2, 2004 | 12:07 PM
stereomandan's Avatar
I'm considering this as well. Mainly because I'm going to '94-'95 single cat headers.
How important is the crank position sensor and what are it's benefits?
Dan
Old Mar 2, 2004 | 01:52 PM
Hotwire's Avatar
Dan
crank sensor is on the 96+ obd2 cars, it's in the 7 o'clock position behind your balancer. it reads the crank revs and relays that info to the ecm, like a abs/speed sensor. If the engine experiences a misfire, it can tell the crank lost momentum, and it can tell what cyl didn't fire, thereby helping you determine which cylinder is misfiring. I think they stepped away from using the low res/high res signals from the opti and replaced it w/ the crank sensor. I know on non lt1 motors if the crank sensor isn't working right, the motor won't run.
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
