OBDI in 94-95 Impala Same as OBDI in F-bodys correct??
Old Oct 28, 2005 | 11:41 PM
asudecat's Avatar
Im needing a OBDI for my 96 bird.
One out of an Impala is the same correct?
Old Oct 29, 2005 | 12:05 AM
Ram Air 9C1's Avatar
Re: OBDI in 94-95 Impala Same as OBDI in F-bodys correct??
The PCM physically is the same but the program is different.
Old Oct 29, 2005 | 12:21 AM
asudecat's Avatar
well as long as I have it tuned for my specs it's fine right?
Old Oct 29, 2005 | 12:28 AM
sssalah's Avatar
Yes, the differences are the maf tables due to different sensor size and the additional knock sensor on the b-body. If reflashed with an f-body tune it will run fine.
Old Oct 29, 2005 | 12:31 AM
asudecat's Avatar
great ....thanks
Old Oct 29, 2005 | 09:15 AM
Hotwire's Avatar
What's the difference in the MAF sizes? I know the f-bodies are 3.5" are the impala / caprice smaller?
Old Oct 29, 2005 | 09:40 AM
DarinsTA's Avatar
yes, quite a bit.
Old Oct 29, 2005 | 10:56 AM
Dave89IROC's Avatar
Originally Posted by Darins94TransAmGT
yes, quite a bit.
impala/caprice use a 3" MAF
Old Oct 29, 2005 | 12:13 PM
96capricemgr's Avatar
You could also use a pcm from a 94-5 Caprice sedan or wagon Roadmaster sedan or wagon, or Fleetwood even if the Caprice pcm is from a 4.3L V8 car yes V8 it is called an L99 and looks exactly like a LT1. These all use the same exact part number pcm as the f-body. The Impala for all practical purposes was just a TRIM package on a Caprice the mechanical differences are so small as to not be particularly important, they guys with Impalas don't like it when you say that though, truth hurts sometimes.
Old Oct 30, 2005 | 05:42 AM
hvyss's Avatar
Thanks Dwayne, you hurt my feelings. As for the PCM as long as it is flashed for your setup it will work fine.
HVY SS
Old Oct 30, 2005 | 07:18 AM
HVY SS
Look at the ET page that cam I bought from you is finally working right now that I bought some headers.
The b-body computers programming also differs in AC control fueling and spark it would run in an f-body but I wouldn't drive it.
Old Oct 30, 2005 | 12:18 PM
1996LT1NY's Avatar
Spoken like a Caprice owner with a case of Impala SS envy....
Old Oct 30, 2005 | 01:10 PM
Nah I am not one for asthetics which the SS definetely has, hell after the deer hit I have not had the blue and silver nose painted red to match the rest of the car even that would cut into the mod budget. Been over why a Caprice fit my needs better in the past don't need to rehash them hear. I mostly just wanted to let guys know the variety of cars they can source pcms from and especially in the case of say a L99 Caprice you might just pay less for the same exact hardware.
Old Oct 30, 2005 | 04:19 PM
hvyss's Avatar
Good to here Dwayne. How many miles have put on the ZZ3 since I sold it to you? I put 15k on it if my memory serves right.
HVY SS
Old Oct 30, 2005 | 04:38 PM
Better than 30K since I put it in. If you look close that puts me at number two stock heads with aftermarket cam I have a few things up my sleeve going to shoot for 12s full weight before I start pulling stuff off. This was on 87 octane wonder what the bump to 93 will do for me?
