OBD2 -> OBD1 conversion, resistor mod in PCM to work with OBD 2KS
Old Jun 21, 2003 | 04:10 AM
NJLT1SS's Avatar
Hey guys, I have an OBD1 PCM for my 97 SS, and I want to be able to switch between PCM's without having to change the knock sensor. I was told that in the OBD1 PCM, I can solder bridge pins 21 and 22 together on the blue connector, and then run a 3.9K resistor from that point to ground? I am 90% clear on doing this, but I would really like to see a pic ,write up, or diagram of this done. Does anyone have this on a website, or can take a pic of this already done on their PCM? I really dont want to screw this up, I have already have had this PCM repaired once.
Nick
Old Jun 22, 2003 | 07:32 AM
NJLT1SS's Avatar
anybody?
Nick
Old Feb 20, 2005 | 08:27 PM
hot white z's Avatar
Re: OBD2 -> OBD1 conversion, resistor mod in PCM to work with OBD 2KS
www.charm.net/~mchaney/knock.gif
might not be exactly what you're looking for, but it sounds like you've already got the right idea
Old Feb 21, 2005 | 08:09 AM
97s10ondubs's Avatar
ion can mod your obd1 to work with your obd2 sensor, he did it for me, madz28.com
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
