Obd2 to obd1 conversion
Old Jul 9, 2005 | 11:20 AM
MichiganSkip's Avatar
Going from 2 to 1 What needs to be done? Just swap the PCM?
Old Jul 9, 2005 | 03:06 PM
96capricemgr's Avatar
Re: Obd2 to obd1 conversion
There are a couple options one is to solder a couple resistors inside the pcm to make the OBd2 knock sesnors work with the OBD1 pcm. A guy on lsitech.com claims you can also accomplish a similar sort of thing with programming alone I haven't tried it YET. The third option and last thing I would recommend would be swapping the knock sensor but then you would not be able to swap back to your OBD2 pcm and you never know when it might come in handy.
Old Jul 9, 2005 | 05:01 PM
jchevy's Avatar
I pulled my PCM apart and soldered in some resistors. This way i can switch back to OBD2 for emissions quickly and easily.
Old Dec 16, 2005 | 07:43 PM
Paul94Z's Avatar
couple quick questions.. 1 what values of resistors and where to solder and 2, can you use the 95 style cables and tunercat to flash the new OBD1 computer?
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
