OBD1 LT1 Max Comp RPM???
Old Jan 27, 2007 | 02:57 AM
Boostwhat's Avatar
How high can you turn an LT1 with a stock re-burned computer? Im looking to spin it kinda high
Old Jan 27, 2007 | 03:42 AM
Joe B's Avatar
Since it can't be totally removed (which is what I wanted in my case since I use an MSD box for the revlimiter) my factory PCM was set at 7200 rpm's which I was told was as high as it could be adjusted(for anything)........Joe
Old Jan 27, 2007 | 06:07 PM
Boostwhat's Avatar
So what other options do I have? Because I would really like to use my setup to its true potental. Like lots and lots of rpms...
Old Jan 27, 2007 | 06:52 PM
95Bird's Avatar
Mine struggled to go over 7000..sometimes it would..sometimes it wouldn't. I hear ed can get it to go higher but I just converted over to a dfi system. You can spin it to 12000 if you want with any of the aftermarket computer setups.
Old Jan 27, 2007 | 08:36 PM
sbs's Avatar
sbs
Were you thinking the answer has changed since the last time you asked it?
http://web.camaross.com/forums/showthread.php?p=4255326
Old Jan 27, 2007 | 11:34 PM
STREETLETHALZ's Avatar
Lmao......
Old Jan 28, 2007 | 11:35 PM
Boostwhat's Avatar
Quite possibly, I was hoping that someone with a little more insight would chime in. Hence the exposure via the repost. The other post was mostly reguarding the mechanical limit of a different setup. I do not have the funds to purchase a fast system on a college budget and am mereley seeking a more cost effective alternative. Thank you.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Roadie
Feb 16, 2015 10:34 AM
Burn_Out
Aug 18, 2002 08:49 AM
