OBD I swap question
Old Mar 8, 2005 | 09:00 PM
RE AND CHERYL's Avatar
OBD I swap question
Just courious how those of you with OBD I swaps scan your cars. Since a OBD I scanner won't plug into an OBD II port and an OBD II scanner won't scan an OBD I PCM. The reason I ask is because I recently swapped the dash in my 94 to a dash from a 97 and it now has an OBD II diagnostic port. I guess I could just swap over to the OBD I port.
Old Mar 8, 2005 | 09:25 PM
disco192's Avatar
Re: OBD I swap question
You basically set it up like a 95 which had OBD1 computer and OBD2 port. You will need an OBD2 cable and can use a laptop with freescan or datamaster. You could also get a scanner that reads both if you want. They usually come with multiple cables.
Old Mar 9, 2005 | 08:04 AM
I've got an Auto Xray scanner with multiple cables but haven't tried it yet. I know the 95 cars had an OBD II port but it was pinned differently.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
