o2 simulators???
o2 simulators???
just purchased the sims,and was wondering if they connect to the wire connection,or to the (hard to unbolt area)other end(bolted area),BECAUSE TRIED THE EASY WIRE END,AND DOES NOT CONNECT AT ALL,SO IF ANY ONE COULD PLEASE HELP,ME I'D APPRECIATE IT?
What year car do you have? I'm thinking, possibly, you're trying to replace the pre-cat 02's with the sims. Do the sims have a square connector and you can't connect to a flat connector?
Put some info about your car in your sig.
Still haven't said what year car you have. Sims are for post cat 02's, OBDll, '96-'97. They tell the PCM that the cats are still working if you have deleted them. You don't replace the pre cat 02's with sims. The pre cat 02's give the PCM feedback to determine your A/F ratio for normal driving.
