O2 Simulators
Old Oct 19, 2003 | 08:18 PM
Chevycobb's Avatar
O2 Simulators
Ok, I need to pass my emissoins, and I probably won't with a gutted cat. Is there anyway I could pass without switching the cat?? Someone told me that O2 Simulators might work, is that true?? Anyother ideas?????
Old Oct 19, 2003 | 08:25 PM
AsianSensation's Avatar
O2 sims doesn't lower the emissions. Just trick the pcm thinking there's a cat in place. If you have OBD1, there's no provision for a O2 sim.
Old Oct 19, 2003 | 08:27 PM
RamAir95TA's Avatar
O2 simulators would make your car run worse. They're designed to trick the PCM into thinking that you still have your rear O2 sensors. If you want a shot at passing, you're going to need your O2s. Simms are for replacing the rear, NOT the fronts. They also use a different 4-pin square connector.
Also, if your car still retains all emissions components (EGR, AIR, etc.), and is running properly, there's still a chance that you can pass, even without a cat. Only one way to find out.
Old Oct 19, 2003 | 08:28 PM
RamAir95TA's Avatar
Damn you Wing.
Old Oct 19, 2003 | 08:32 PM
Sorry Joe.
Old Oct 19, 2003 | 08:34 PM
Chevycobb's Avatar
How would I trick the pcm to think that there is a cat?
Old Oct 19, 2003 | 08:39 PM
I meant the O2 sims tricks the pcm.
Old Oct 19, 2003 | 08:50 PM
Chevycobb's Avatar
oh ok, sorry about that...so basically I just have to hope it will pass with the cat. I replaced the O2's because I knew one of them was bad, so I guess I just have to hope that that is enough
Old Oct 19, 2003 | 08:51 PM
RamAir95TA's Avatar
You could try and unplug a few injectors?
Just kidding! Good luck!
Old Oct 19, 2003 | 08:54 PM
Chevycobb's Avatar
HAHA if we happen to see that I fail...who knows what lengths i'll go!
quicksilver97ta
May 5, 2021 07:41 PM
Cream
Feb 13, 2004 06:16 PM
matts_z28
Jan 19, 2004 09:47 PM
Mystic97Z
Oct 19, 2003 07:41 PM
busta9876
Jun 28, 2002 02:22 PM
