o2 sensors
Old May 11, 2004 | 05:52 PM
Punkillr's Avatar
o2 sensors
how hard are these to replace? also how about tranny mounts?
Old May 11, 2004 | 07:29 PM
ping0317's Avatar
funny you ask.. that is my next project. For the 02 sensor go to autozone to test it before you buy one. The trans mount is very easy to do with a lift...
Old May 12, 2004 | 12:38 AM
Lt1t56's Avatar
Transmission has 1 mount easy to do. Remove nut holding mount to crossmember then use floor jack to raise trans and remove 2 bolts holding mount to trans. O2 sensors easy with my MAC mid-length headers, never had to change them with my stock manifolds so not sure on that but would bet probably not hard also.
Old May 12, 2004 | 09:02 AM
ping0317's Avatar
is there a tool you need if you want to remove 02 sensor? I have mac mid length too. How do you like yours?
Old May 12, 2004 | 09:04 AM
Red96Lt1's Avatar
They make a special tool, but it's not required. A wrench is fine.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
