O2 Sensor wire extention?
Old Apr 25, 2004 | 07:40 PM
JONEZ_Z's Avatar
I put in my Jett Hott long tubes and now my wires arent long enough to make it to the sensor. Well,..they make it but it is streached tight and i cant leave it that way. Do they make an extention or do i have to splice the wires. Thanks
Old Apr 25, 2004 | 07:43 PM
97FormulaWS-6's Avatar
They make extentions.... you can get them from Thunder Racing or Tbyrne...
Or you can extend the harness'...
Old Apr 25, 2004 | 07:44 PM
AdamZ1LE28's Avatar
Yes thunderracing.com makes an extension for the front 02 sensors. whatever you do, dont splice them. the sensors are very sensitive and cant be spliced/re-attached without harming them.
Old Apr 25, 2004 | 07:50 PM
True, but you can extend the vehicle harness with ZERO side effects...
Old Apr 25, 2004 | 08:03 PM
JONEZ_Z's Avatar
Ok, found it, thanks guys. Do you guys know if Thunder Racing is good with quick shipping?
Old Apr 25, 2004 | 08:08 PM
Thunder has one of the best CS reputations around...
And from my experience they ship as fast if not faster than Summit...
Old Apr 25, 2004 | 08:32 PM
disco192's Avatar
How would it harm the sensors? It would cause a bad reading if the wires didnt get a good connection, but how is cutting and adding extentions with wire any different than pre made extentions with connectors?
As long as you use good wire and make good crimps, it will register 100% accurate, and it wont harm the sensor.
Old Apr 25, 2004 | 08:35 PM
95_LT1_6SPD's Avatar
It has something to do with some other reading, but i thought it was bs so i extended them anyways, and my car runs fine
Old Apr 25, 2004 | 09:00 PM
Not completely so.
The sensors draw reference air through the factory wiring, so disturbing the wiring harness on the sensor itself, is not recommended. Modifying the sensor's harness may cause the sensor not to work properly/accurately.
Old Apr 25, 2004 | 09:11 PM
tagz's Avatar
YEh, i was told using butt connectors, or any connectors of this sort will screw with the resistance. I did not try it, but i know for sure soldering them works. Thats what I did and its reading great
Old Apr 25, 2004 | 09:18 PM
A point of my post was that maintaining the integrity of the insulation is just as important as the wire inside it. IMO, soldering would be even more invasive than using butt connectors in this instance.
Fatdog2
Feb 13, 2015 08:19 PM
squarehead
Jan 15, 2015 07:02 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
