O2 sensor - trick
Old Aug 16, 2005 | 02:00 PM
  #16
RedRyder518's Avatar
Re: O2 sensor - trick
I have a slow responce for my sensor. I tried switching it the other side and the code followed the sensor so I know it is that and not the wiring. Maybe I could try some electronics cleaner on it? Or should I use starting fluid?
Old Aug 16, 2005 | 02:21 PM
  #17
97FormulaWS-6's Avatar
I've cleaned them with a MAPP torch before when they got fuel fouled and all carboned up... worked great, and I'm still running those O2s 10K later...
Old Aug 16, 2005 | 07:43 PM
  #18
Jeremy_30th's Avatar
Originally Posted by 97formula1234
BTW how do your LT and ST fuel trims look?
LT B1 2.3%
LT B2 0.0% Those seem ok to me....
ST B1 -100%
ST B2 -100%
not sure why this is like that maybe because there isn't enough history? I reset the PCM not to long ago for air pump issues. please some one explain these short term trims to me
EDIT* Just read on AT it maybe due to canister purge. Normal.
so I guess I will be keeping a eye on those. hopefully thats why its like that
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
colts0455
Jul 24, 2015 04:51 PM
Noct
Jul 14, 2015 01:18 AM
pimpen1024
Jul 8, 2015 09:08 PM
