o2 sensor simulators
Old Jul 2, 2009 | 09:59 PM
96SSIndeed's Avatar
Ok so i have been having problems with my o2 sensors fouling out and having to be replaced. I was looking into maybe getting some simulators to solve this problem. But, i read that the connector for the front o2 sensors in a four wire flat plug, which is the o2's on my car. I have Pacesetter long tubes,and ory pipe so these are the only 2 sensors on the car. I also read that these control the fuel trims, so they couldn't be simulated out. I was looking to get some insight into this, my car will run good for a while with new o2 sensors and then they will foul out and the car begins to run like crap. Also, do you think just getting a dyno tune will cure this problem?
Thanks Chris
Old Jul 2, 2009 | 10:04 PM
It is correct that you cannot simulate the front sensors, so that is out. Some research and data from your O2s might help. When you start modding the engine, a tune is often required for it to run it's best.
Old Jul 2, 2009 | 10:16 PM
96SSIndeed's Avatar
i was thinking of getting a dyno tune because that seems the only way. I live about 15 minutes from futral motorsports and about 30 minutes form my usual thunder racing, so it wouldn't be a problem. also, do you know if my car came with rear o2 sensors? i need to look and see if i can find the plugs but i don't remember seeing them.
Old Jul 2, 2009 | 10:24 PM
1996s would have rear O2s as stock.
Old Jul 2, 2009 | 10:33 PM
96SSIndeed's Avatar
thanks
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
