O2 sensor removal issues
Old Jun 16, 2003 | 07:05 PM
Chewbacca's Avatar
1996 Z28, factory cats and manifolds, original O2s
Did a search but need more detailed info
It appears as though I can get to the driver's side by simply using a good deal of patience (I hope). My issue is the passenger side.
Dropping the Y pipe is out of the question (until I get headers ). The bolts are so badly rusted the threads are barely visible. No way these will come off without breaking.
Can I get to the O2 by dropping the starter? After taking a look I'm not sure I can fit an arm and socket up through that opening.
If dropping the starter won't give me the needed room, what are my options with broken Y pipe bolts?
Thanks guys.
Old Jun 16, 2003 | 07:13 PM
got_hp?'s Avatar
i had to drop my ypipe.........there was no way it was coming out without it.........but i have thick forearms
my ypipe bolts were pretty rusty, but letting them soak overnight with PB Blaster worked wonders.
Old Jun 16, 2003 | 07:37 PM
Z95m6's Avatar
my single cat car wasn't too hard at all. On the other hand my friends 97 was impossible he just waited until he did headers.
Old Jun 17, 2003 | 01:11 AM
Van5150's Avatar
I just replaced both my O2's and your right the drivers side was easy. I changed my pass side O2 through the top with a borrowed O2 socekt from my 5.0 buddy (apparently they are both the same size). Took about a half hour to get it on there and turn it in tiny increments, really not much room. And oh yeah, I believe me spraying PB on there and let sit for 10 minutes was helpfull.
Iamherefornow
Jan 26, 2015 04:57 PM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
