Which O2 sensor??
Old Apr 7, 2004 | 05:53 PM
Allwaysbroke Z's Avatar
Question Which O2 sensor??
Went to autozone for new O2 sensors and they had 2 different ones for the 1995 z. they both had 4 wires but One had a rectangular wire harness with the wires already on, and the other had the 4 but no harness attatched. The one with the non-harnessed wires comes with a Square wire harness that you hook up yourself with 2 on top and 2 on bottom. the other one had the 4 wires lined up 4 wide. SO.... which one do i need?
Old Apr 7, 2004 | 05:55 PM
Red96Lt1's Avatar
flat is for the front, square is for the rear (after cat). You have 4 O2 sensors.
Old Apr 7, 2004 | 05:57 PM
Someone told me on a single cat 1995 there were only 2. one before the cat and one after. and since i dont have a cat. does it make a difference?
Old Apr 7, 2004 | 05:59 PM
jkipp84's Avatar
If you have a single cat, you've got 2 before the cat, none after.
Old Apr 7, 2004 | 06:11 PM
Red96Lt1's Avatar
My bad, I was thinking for dual cat. Sorry.
Old Apr 7, 2004 | 06:13 PM
OK. so if i have 2 before the cat will they both be the same with the harness and the 4 wires in a row?
Old Apr 7, 2004 | 06:17 PM
93Z286Speed's Avatar
my single cat 93 has 2 wires.. but i think you might have heated O2's? Thus the 4 wires..
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
