NSA rocker help!!
If you are using standard rockers (there are some that you do torque down, such as the factory rockers on an LT4), then you adjust the lash using a procedure. Take a look at Shoebox's Website
It has the procedure to follow.
BRAD
BRAD
Originally posted by 96ta(nick)
they are pro mag nsa rockers it says in the instructions to torque them down and that is all it says..
You have to adjust each, individually.
