Now on hour 8 of water pump install
Old Aug 3, 2007 | 02:10 PM
micfly83's Avatar
First we cant get to the drain plugs on the back of the block, cant get our hands into what we think the plugs are..
We got all the hoses off, and had a nice bath in coolant
We got 5 of the bolts out of the water pump but the 6th one towards the back of the pump...theres no possible way to get to it.
We took off what we think is the AIR pump but that did absolutely nothing to help
the optispark is soaking wet on top of that
Can someone help us out?
The haynes manual is pretty much worthless
Removing water pump
Step 1) Remove Water pump
Install
reverse of step 1.
Old Aug 3, 2007 | 02:33 PM
'94 Bad A Z28's Avatar
Where in Orlando are you, I might be able to come over and help.
Old Aug 3, 2007 | 02:38 PM
joeSS97's Avatar
^nice offer,you should take him up on that.Sounds like you need the help.
Old Aug 3, 2007 | 02:43 PM
micfly83's Avatar
Ucf
Old Aug 3, 2007 | 02:45 PM
JoeliusZ28's Avatar
take that up and buy him a case of beer
Old Aug 3, 2007 | 02:59 PM
Werd, I live 5 minutes down the road from UCF.
Old Aug 3, 2007 | 03:00 PM
Give me a call....
XXX-XXX-XXXX
Eddie
Last edited by '94 Bad A Z28; Aug 3, 2007 at 03:12 PM. Reason: Removing phone umber
Old Aug 3, 2007 | 03:02 PM
LiENUS's Avatar
You gotta take off the bracket that the air pump bolts to
Old Aug 3, 2007 | 03:10 PM
wrd1972's Avatar
Now were cooking with gas.
Old Aug 3, 2007 | 03:14 PM
They got everything off and just had some concerns about somethings, but everything sounded fine.
If you have anymore questions or would like me to come by and help out just call me back and let me know.
Old Aug 3, 2007 | 03:28 PM
Bersaglieri's Avatar
What plugs? Back of block what are you doing there?
What did you think was in there?
Calm down, we've all done it, there is definately a way
If you dont have emissions throw that part away along with all the worthless tubing it uses
Towel
Probably
Removing water pump
Install
reverse of step 1.
I know it doesnt say that.
Sounds like you went into this without preparing for it at all. One of the first mods I ever did to my car was removing the waterpump and opti, and putting new ones in. I researched this site alot before taking it on. I used the Haynes and some things I read on here and it went very easily. I know I am coming off like a *****, but when you come on here acting like it's everythings fault but your own youll get no sympathy from me. Hopefully from now on you'll do a bit more thinking and planning before you just tear stuff apart.
-Dustin-
Old Aug 3, 2007 | 04:10 PM
Danny McAdams's Avatar
What in hell are you people trying to do? Your post is the best laugh I've had all day. Gee guys has no one ever given you a clue how to do that job. If you give me your ph# I will try to walk you through it, I will pay for call. Danny Mc
Old Aug 3, 2007 | 04:30 PM
strbcks241's Avatar
I know I had the pressed fit tubes for the heater hoses on mine come out when I was driving and I had to put in the new water pump in a coffee shop parking lot, in the dark, and without a full tool box, it was a pain in the ***(I didn't have the cash for a tow truck)- and hayne's manuals blow. My favorite phrase is " due to the complexity of ________ it is best left to professionals, and will not be covered in this manual" haha. Which bolt are you having a hard time getting to? The one all the way to the left behind the pulleys or the one to the right? I pulled the air pump and used a swivel and short extension for the right, and I monkeyed around with the left one for 10 minutes before I could get it in. Make damn sure the air pump hoses are all in good condition and connected, though.. One of mine led to my opti and it was cracked..
Old Aug 3, 2007 | 04:33 PM
If y'all read the thread, it sounded like they had it covered (at least to me).
Old Aug 3, 2007 | 05:46 PM
Stl94LT1's Avatar
Sounds like someone needs a Service Manual.
