nothing but air comming out of top bleeder valve when car is ideling
Old Jun 28, 2004 | 11:39 AM
93transam1234's Avatar
is that normal? if i look into the radiator whit the car ideling i can see water squart out of the top hole where the line comes in but it only sprays out about every 2-3 seconds not a steady stream, but if i hit the throtle i will get a steady stream comming out
is that what i should exspect or is there a posable problem?
Old Jun 28, 2004 | 12:25 PM
ChickenScreamer94's Avatar
Make sure the thermostat is open, it always works with me. Make sure it is atleast at 180* and open the lower bleeder first. It sounds like you just have a lot of air in yours. My car is the same way, just keep it open, eventually coolant will come out. Then open the top and you are done.
I am assuming the bottom bleeder is not "bled," so that is probably why it is not steadily coming out.
Old Jun 28, 2004 | 12:59 PM
when ever i open the bottom bleeder coolant always flows out with no air pockets.
BUT i didnt have both of them open at the same time when i did that test above, should i have both open at the same time?
Old Jun 28, 2004 | 01:06 PM
An operating system must be bled when there is pressure in the system. If you had the cap off, you need to give it time to pressurize.
Old Jun 28, 2004 | 01:56 PM
so i should start her up bring her to temp (about 170 -180)
then open the blledr screws?
both at the same time or one at a time or does it matter?
How do i protect the opti form the water? last time i did it with the car running i was spuddering around for 2 days LOL
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
whitehooptie
Jun 20, 2002 08:59 AM
