not starting up
Old Mar 4, 2007 | 01:52 PM
lt1 beast's Avatar
not starting up
ok so the lt1 has been driving me crazy for a week now. I just put 2 new head gaskets, a timing chain, msd cap and rotor, and msd 8.5 wires running up to autolite double platnum plugs. the mass airflow sensor was ported and i put pacesetter long tubes and a 3" magnaflow cat back system on. The car starts for 1 second and then dies. today i removed to optispark and checked inside it and found a some milky looking oil deposits from when my engine became flooded by rainwater. the motor was spining freely after i removed the water and changed the oil. but now it wont start. could this be a bad optispark or is it something more? Im in despirate need of solutions any input will be greatly appreciated............. Thanks in advance
-steve
Old Mar 4, 2007 | 01:56 PM
red 95 z28 lt1's Avatar
do you have proper fuel pressure, can u hear the fuel pump prime, are u sure u have compression, valves adjusted too tight keeping them slightly open? any codes, more info needed put in a sig to let us know of what you got
Old Mar 4, 2007 | 04:35 PM
lt1 beast's Avatar
good to know you have the same car
Old Mar 4, 2007 | 10:23 PM
mrmint69's Avatar
I would be concerned with anything getting on the opti. You said it had rain water on it and this is after the work done. Is the oil in the opti or on the out side?
Old Mar 5, 2007 | 01:15 AM
94/96ZsM6s's Avatar
most likely vats or ingnition problem because of the opti being soaked in water....
Old Mar 5, 2007 | 12:04 PM
lt1 beast's Avatar
yes the water was inside the dristibutor as well as outside
Old Mar 5, 2007 | 12:31 PM
lt1 beast's Avatar
just a quick thought could the timing chain being off by 1 tooth cause the motor to not start. and the knock sensor going off from my long tubes as well cause this?
Old Mar 5, 2007 | 02:28 PM
2000GTP's Avatar
The timing chain being off could be a possibility. However, the long tubes giving off enough "false knock" to cause the car not to run is unlikely.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
