Not running right (supercharged)
Old May 28, 2005 | 10:06 AM
ZephTheChef's Avatar
Ok, I have a problem. I bought this car and immediately after unloading it from my trailer, it overheated. I bought a new thermostat and it was running and driving great after that. I put maybe another 50 miles on the car, ran a few 1/4 miles (not at full throttle, but getting close) and it was still running fine. I parked it after taking one of my friends for a ride, during which I ran it pretty hard for 1/4 mile and then just cruised around for about 10 minutes and everything was fine. The next time I drove it, just about an hour later, it was harder to start and popped when I really got on the gas, but still had plenty of power. I only have driven it once after that time, and it popped a little bit at idle and quite badly when I went above about 1/2 throttle, yet again the car still seemed to have all of its power (except when it popped). After that I did not drive the car, but I did start it up a few times and just let it idle...after a few times of doing this the car started to die at idle and eventually wouldn't start up again, just crank. Then the starter went out, so I haven't touched it in a few weeks. Any advice would be appreciated. Thanks.
here are my car details:
1993 Z28 Chevy Camaro w/ 96' Supercharged Corvette Engine
Car Details
59,000 Original Miles
Excellent Condition Inside and Out
Black Leather Interior
Red and Black Exterior
Fiberglass (Steel Reinforced) Cowl Induction Hood
Aftermarket 16" Wheels; 295/50 Z16 Tires
No Scratches or Dents
2" Eibach Lowering Springs
Engine Details:
1996 Corvette Engine (.030" Over)
1,500 Mile on Engine
Approx. 550 HP at the Wheels
Fuel Delivery:
BBK 41 lb. Fuel Injection
BBK Fuel Regulator
BBK Twin 58mm Throttle Body
Holly Secondary Fuel Pump
Billet Aluminum Fuel Cooler (Works with Dry Ice)
AN Braided Fuel Line
Ported and Polished Intake
Supercharger:
Pro Charger P600 Oil Cooled Supercharger
Inter cooled
11 PSI of Boost
All FelPro Gaskets (made for Supercharged engines)
Engine Internals:
New GM Forged Steel Crankshaft
New Child & Alberts Forged Rods
New JE 9:1 Forged Pistons
New Comp Cam's Custom Ground Cam for Super Charger
New Comp Cam's Springs & Containers
New Comp Cam's Lifters
New Crane Roller Rockers
New Stainless Steel Valves
New Aluminum Ported and Polished LT4 Heads
Engine Accessories:
ATI Balancer & Crank Trigger
Mallory Pro Master Series Coil
Taylor Racing High Temp Plug Wires
MSD Boost Timing Modular (4 Stage Digital Retard)
Autometer Gauges for Fuel Pressure, Boost
Oil Pressure and Water Temp Gauges (Not Installed)
Edelbrock Headers which attach to 4" Exhaust
Muffler Bypass to convert to straight headers
CSI Electric Water Pump
CSI Mini High Torque Starter
16" Electric Flexalite Cooling Fan
Flexalite Trans Cooler
Aluminum Bow-Tie Valve Covers
K & N Air Filter
New 120 amp Alternator
New Power Steering Pump with Remote Reservoir
Drive train
Rebuilt 4L-60 Street /Strip Transmission
Street Fighter 3200RPM Stall Converter
Aftermarket Driveshaft
4:11 Rear with Eaton Posi
Old May 28, 2005 | 10:07 AM
Re: Not running right (supercharged)
Also, I thought I would add that the starter was just replaced by the previous owner, so I suspect he might have had this problem as well. The starter would have had less than 200 miles since new.
Old May 28, 2005 | 11:01 AM
slimdawson's Avatar
Out of curiousity, what kind of heads?
As far as the problem. Sounds like ignition to me from the info provided. Swap out the Mallory coil for stock and see what happens. Also, did any codes come on?
Old May 31, 2005 | 02:11 PM
LT4 heads...I don't have a diagnostic tool to check the codes myself, but I'm going to have it looked at as soon as I can find a trailer to load it on (tricky situation, its lowered).
Highlander
Jan 12, 2020 02:13 PM
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
guionM
14
Jun 19, 2002 08:30 AM
