Not the normal window problem....
Old Sep 17, 2003 | 02:00 PM
craigffb's Avatar
Both motors are pretty new as well as all the switches, so here's what the problem is. My passenger window will not go down from the drivers side switch until the switch on the passenger side is pushed then they both work fine. Then when the car is turned of it all starts over again. Hope that makes sense. Anyone got an ideal on this one, relay maybe?
Old Sep 17, 2003 | 10:08 PM
Drew778/94Z's Avatar
Might just have to change the switch, could just warnout.
Time for a new car, maybe and LS-1
Old Sep 17, 2003 | 10:13 PM
craigffb's Avatar
Actully the switch is new. It was cheaper than an LS1. I swaped the relay with the one for the power seat and it's working fine now. Guess I can keep it for a few more years.
Old Sep 17, 2003 | 10:21 PM
I would check the security of the connection on the passenger switch, first. The next suspect would be that switch. Might as well look at the connection on the driver switch, too.
Old Sep 17, 2003 | 10:26 PM
craigffb's Avatar
I checked them both and they were fine. It's working fine now that I swapped the relays. The seat works fine as well. I don't know what the problem was, but every thing is working now.
Old Sep 17, 2003 | 10:31 PM
Relay? You mean the breaker in the fuse panel?
Old Sep 17, 2003 | 10:35 PM
craigffb's Avatar
Yes, that what I ment.
Old Sep 17, 2003 | 10:38 PM
You're right that is not the normal problem.
I hope your fix takes care of it.
Old Sep 17, 2003 | 10:40 PM
craigffb's Avatar
Me too. It wasn't making much sense because it would work fine from the drivers side switch after I hit the switch on the passenger side door. I still don't know what the heck it was, but it works now so I guess I won't worry to much about it
Old Sep 18, 2003 | 01:25 AM
I think you should play it safe and get the LS-1 anyway
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 10:09 AM
plattted
9
Sep 20, 2015 11:23 AM
mmf_1013
Sep 12, 2015 08:56 PM
z28cam1993
Sep 9, 2015 04:08 AM
