Not To Happy With My Track Times
Old Jul 1, 2007 | 05:33 PM
clcam97's Avatar
I run consistent 13.9 @ 102mph with a 0-60 of 2.1. My mods are LT pacesetters,SLP CAI,LT4 KM,airfoil, MT drag radials,and lowering springs 1.7, its a 97z,6M,stock 3.42s. Are my times about right or should i be doing a bit better? i also have new ac delco opti,8mm Taylor wires and coil.
Old Jul 1, 2007 | 05:45 PM
exgmguy's Avatar
Are you spinning or bogging? How fast are you shifting? Your 60ft should be better. A lot of LT1's are running similar times at my local track with similar combos. You are making decent mph, so you are on the right track.
Old Jul 1, 2007 | 05:53 PM
mrmint69's Avatar
The headers and drag radials should give you better times than stock but not a hugh advantage. Probably need more practice to get in the mid 13's or a minor tuning issue.
Old Jul 1, 2007 | 05:54 PM
2000GTP's Avatar
Having a manual on top of the lowering springs might be hurting your launches as well.
Old Jul 1, 2007 | 05:58 PM
clcam97's Avatar
i did spin a lot,the track wasnt well prep i guess.Maybe i should lunch at lower rpm 3,000 maybe?i was shifting at 5,800rpm and launching at 4,500
Old Jul 1, 2007 | 06:00 PM
2000GTP's Avatar
Thats all you can do, practice and see what works. Just try to get those sixty footers down.
Old Jul 1, 2007 | 06:12 PM
reamo04's Avatar
also - where are you located? how was the weather? those two things can GREATLY affect your times
Old Jul 1, 2007 | 07:11 PM
klrz28's Avatar
stock motor? or built up? its all how your susupension is set up
Old Jul 2, 2007 | 01:09 AM
SS MPSTR's Avatar
you might want to look into lca relocation brackets. with the car lowered, the IC is about 15 feet behind the car.
Old Jul 2, 2007 | 04:26 AM
clcam97's Avatar
Im in phoenix AZ,humidity was 0% and altitude only 700ft.by the way whats the IC? And everything its stock except for the parts that i listed.
Old Jul 2, 2007 | 06:23 AM
Ironxcross's Avatar
man, i ran the same times, with a worse 60' (2.3), w/o LT's, or RRs, or DRs, and 110k on the clock.
something has to be going on over there
Old Jul 2, 2007 | 07:04 AM
JoeliusZ28's Avatar
i cut 2.1 60 foots on street tires bro. Lower springs definitely dont help, but drag radials should more than make up for that. Ive also made up a couple tenths just getting better at shifting too.
Old Jul 2, 2007 | 08:17 AM
Javier97Z28's Avatar
Moderator
Your 60' is god awful on MT DR's... work on that.
Old Jul 2, 2007 | 12:41 PM
clcam97's Avatar
lowering springs will affect my times that bad?i still have the originals springs,you guys think they will help improve my launch?
Old Jul 2, 2007 | 01:41 PM
neil350's Avatar
With it spinning so bad its hard to tell what it really runs. But I imagine if it hooked, say 1.7s or 1.8s, probably be capable of running low 13s, high 12s.
