not happy with my dyno results
Old Sep 2, 2004 | 01:24 AM
Seal's Avatar
just got the car on the dyno, here is what i got
cc306 w/1.6 RRs
jethot long tubes
custom ypipe/i pipe, no muffler
comp tune from madz28
kn intake
3.23 a4
dynoed best 315rwhp/322rwtq
car was running mid 11s low 12s on the AFR so maybe i can pick up 10more hp if it was tuned right which would put me in the 330ish range i was expecting 340 or so
what do u say? i will get the chart scanned soon
Old Sep 2, 2004 | 01:29 AM
Spinner's Avatar
Re: not happy with my dyno results
Consider rockers may be too tight. You've got 15-20hp on the table with the tune. 335 through an auto isnt so bad. You could pick up a few more with a big TB, electric water pump and pullies
Old Sep 2, 2004 | 01:41 AM
Seal's Avatar
yeah, ure right... those rockers might be on pretty tight, we did 3/4 turn on'em, i'll do 1/2 instead...
well, i dont think i'll need all those mods on there since i'm putting a turbo on it friday :woot: cant wait!
i actualy dynoed it today for before/after tests...
Old Sep 2, 2004 | 01:55 AM
Zeueses 97 RamAir's Avatar
what kind of turbo
Old Sep 2, 2004 | 02:24 AM
Seal's Avatar
its a t04, rear end turbo setup, and before anyone says how much they suck, ya can keep teh comments to urself everyone who has it loves it, and i have 2 friends here who has the kit, and i've been in their car and i love it
Old Sep 2, 2004 | 02:57 AM
Is It An Sts Turbo The Guy Down Here Sells Them
Old Sep 2, 2004 | 05:17 AM
97WS6SCharged's Avatar
Why did you install a CC306 if you're planning to install a turbo?
Old Sep 2, 2004 | 09:24 AM
Seal's Avatar
because i've had my cc306 for 3 months now... if it doesnt work out well i'l gunna swap for a turbo cam, but if it works just for now imma stick with it, with such duration it should be ok/good
and yes its an STS
Old Sep 2, 2004 | 10:10 AM
My Red 93Z-28's Avatar
if it is the set-up I am thinking of, I bottom out enough the way it is, so I would hate to destroy a turbo by hitting a bump in the road.
Old Sep 2, 2004 | 03:46 PM
marshall93z's Avatar
not a very good cam for turbo...
Old Sep 2, 2004 | 05:37 PM
92rslt1's Avatar
Talking Re: not happy with my dyno results
i agree you will be pushing exhaust back into your engine. you might want to sell me your 306 and grab a single pattern turbo cam.
Old Sep 2, 2004 | 05:59 PM
brain's Avatar
I disagree on it being a horrible cam for a turbo. It might not be the "best", but I'm sure its not the worst. One of the guys in MMFF says that the best turbo motors are optimized N/A first. I'd say the 306/847 style cams are pretty good power makers on a stock head LT1. It might not make a ton of boost, probably could use a bit tighter LSA.
Old Sep 3, 2004 | 12:05 AM
Seal's Avatar
yeah, this will be an interesting thing to see, i can change the cam its no problem, but im def not gunna change out the cam if its gunna help me by like 5 hp, not worth all the stuff done imo... plus there is a rebuild on its way soon
anyways, way to off topic hijackers
the turbo will not bottom out, my friend has it on a lowered camaro, and its doing fine
Old Sep 3, 2004 | 12:43 AM
I never said the CC306 wouldn't make power with a turbo. It won't spool as fast, and you'll blow a little boost out the exhaust, but it'll still make power. Maybe it won't hurt as much since the turbo will basically be a cold setup.
Old Sep 5, 2004 | 08:20 PM
92rslt1's Avatar
let me know what happens im gonna run the 306 and later turbo so if it works good i need to know.
