NOt alot of $$$..need some advice before i buy stuff
Ok, well the other day my car started running reall bad all of a sudden, and got real hot, i parked it, and turned it off, then on, it ran rough, kinda smelt like coolant while driving home, was barely running, had to floor it to move. Turned key and heard horrible grinding sound, ended up being a cracked starter.....now that is solved, i wanna know what went wrong with the coolant and stuff, i wanna say my waterpump went south.....i saw some coolant dripping when i got home, and there is coolant spalshed up all under the car, drained the rest of the coolant and it looks ok, oil on dipstick is fine also.....I noticed sludge on each of the 4 hoses that connect to the water pump, also the metal piece that is on the top of the water pump, that the hose connects to, had sludge around it......any ideas???......im on a budget here.....weep whole is dry, but car has been sitting for 5 days.
Magenta_Hearts
Mar 22, 2015 03:36 PM
