Not able to install strut tower brace
Old Jun 14, 2003 | 01:05 PM
thefox1's Avatar
Hi,
looking for some help, I'm not able to install my strut tower brace. It seems to push against the frame underneath the whippers.
here's what it looks like:
http://groups.msn.com/Jasonontheweb/...oto&PhotoID=14
Old Jun 14, 2003 | 01:19 PM
indy500ss's Avatar
Is it bent, I know it is supposed to be mounted under the cowl also, does it even fit under the cowling? Try mounting it to the struts first then see how it fits against the cowling.
Old Jun 14, 2003 | 01:22 PM
thefox1's Avatar
thats the problem, it goes in the struts on one side but then after I can't on the other side bc the center hits underneath the cowl the way the cowl is molded. The brace does not seem to be bent. but there's two bolts in the middle of the brace the don't seem to align anywhere in the cowl.
Old Jun 14, 2003 | 01:41 PM
joeSS97's Avatar
Take that thing back wherever you got it and get a BMR.
Old Jun 14, 2003 | 01:43 PM
thefox1's Avatar
bought it used So unless I can make it fit I have to find for exactly wich model it's for and try to resell it
Old Jun 14, 2003 | 05:01 PM
blown383's Avatar
You need to install the driver side first by slipping it over the strut bolts, then slide the brace underneath the cowl and remove the passenger side strut bolts. Once you do that put your foot in the wheel and step down (this only works if your car is up on jack stands) this will lower the strut studs enough for you to slide the brace over the studs and bolt them down. Good luck. Hope this helps.
-B
Old Jun 14, 2003 | 05:06 PM
Ghettoraid's Avatar
eBay that bitch!
Old Jun 14, 2003 | 07:49 PM
thefox1's Avatar
-B
hummm, good idea. Would it be how you installed yours? (just kinda seemed you know what your doing )
Old Jun 14, 2003 | 08:06 PM
blown383's Avatar
Yup thats how I installed mine....at times its a real bitch so I used a rubber mallet and banged it into place...and at other times I would use a crowbar to take it off.
Here are some installed pics - http://community.webshots.com/photo/...70034213sKAtLO
http://community.webshots.com/photo/...70034467yBtMex
Old Jun 15, 2003 | 01:06 AM
revtime's Avatar
Sounds just like my Granatelli.
Get a big Fn Hammer and pound it in.
No, a rubber mallet or a towel wrapped around the brace and a 2 pound hammer, I have used both.
I don,t bolt up that third mounting point on the brace cause I heard it would crack your windshield and it works just fine.
Old Jun 15, 2003 | 01:14 AM
chasmanz28's Avatar
how does a 3 point kenny brown stb line up on a 96z28, putting mine on tomm
Old Jun 15, 2003 | 01:29 AM
revtime's Avatar
All the 3 point braces that I have seen bolt to the cowl in some way, I have never heard good things about this so I just bolt up the sides and leave the third mounting point alone. 4 bolts and you should be in business.
Old Jun 15, 2003 | 02:24 AM
blown383's Avatar
I've had mine bolted to the cowl area for nearly 7 years now....no troubles....that cracking windshield thing is either a freak accident or myth.
-B
Old Jun 15, 2003 | 02:29 AM
chasmanz28's Avatar
-B
you have any pics of the 3rd point on the cowl by chance blown383?
Old Jun 15, 2003 | 03:46 AM
blown383's Avatar
http://community.webshots.com/photo.../70034213sKAtLO
http://community.webshots.com/photo.../70034467yBtMex
-B
