nos cam????
Old Sep 13, 2003 | 08:08 PM
DTABFORMULA's Avatar
nos cam????
i am spraying a 250 shot direct port and i was wondering the best cam for a nos car is?? im rebuilding the whole short block and any ideas will help i dont want a streetable motor car im only going to run it on nos...
thanks
Old Sep 13, 2003 | 08:21 PM
93formula's Avatar
im runnign a 224/236 xe cam, and i think combo had a 228/240 cam as well, not too sure. but you can run a cc306 and still run nitrous safley.
Old Sep 13, 2003 | 08:22 PM
PoorMan's Avatar
I am not a die hard drag racer but if I was I would have to base my cam on what heads I was going with. The cam should be matched with the flow numbers you get back after your head work since you are planning on investing that type of cash on the bottom end.
Jeff D
Old Sep 13, 2003 | 08:41 PM
WheelmanZ28's Avatar
I would check out some of the nitrous cams at www.cmotorsports.com
They have a HUGE selection and can even make custom grinds. I would give them a call if u have questions, They are EXTREMELY knowledgeable.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
