north jersey motor rebuild?
Old Nov 5, 2003 | 11:18 PM
silverz96's Avatar
hey guys
i am from north jersey and i just rollled my odo. over to 90,000 on my 96 z28 and i need a rebuild. more hp. what should i do? 355 or 383 which is better and any sugestions on someone you have worked with in the north jersey pa region that is good at rebuilding? thanks alot
Old Nov 5, 2003 | 11:26 PM
87beater's Avatar
well do you merely want a "rebuild" or an all out new motor? cause if you want the stroaker its going to cost you a chunk more to do it right! so how much you got?
Old Nov 5, 2003 | 11:29 PM
silverz96's Avatar
I got around 5 grand to play with but that has to make the car run agin. b/c i dotn got much more. i can pull the motor and put it in i just need the motor built to handle my beating on it and it has to move!!
Old Nov 5, 2003 | 11:37 PM
87beater's Avatar
i can get you a hell of a deal on a 383.. all new block.. rods.. pistons and all here if you want me to check.. you said 5g's to get her running? did you want a carb or injector set up?
transam_388
Mar 15, 2015 11:53 AM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
ChrisFrez
Jan 18, 2015 08:05 AM
