Normal O2 sensor behavior at startup..Are mine shot?
Old May 7, 2007 | 06:34 AM
wrd1972's Avatar
On my old engine I thought I remember the O2's reading around a constant 450v at closed loop on my scanmaster.
Mine now under the same conditions are reading different. The left at around 350V and the righ is bouncing and the BLM's are acting strange.
Does this behavior at closed loop cold engine sound normal?
Old May 7, 2007 | 06:39 AM
95LT1conv's Avatar
i dont think they are supposed to be constant. the right is probably good and the constant bad.
Old May 7, 2007 | 06:43 AM
wrd1972's Avatar
That being said I am lost why the two are much different at start up from one motor to another. I thought the O2's did not do jack in closed loop?
Old May 7, 2007 | 09:29 AM
OBE1 95Z28's Avatar
The PCM ignores the O2 sensors in open loop. A cold O2 sensor will read 450mV; as heat from the exhaust start to warm up the O2 sensor the mV readings will start to bounce above and below 450mV. Even though these readings are moving, the PCM will ignore them until closed loop is reached.
Old May 7, 2007 | 09:33 AM
wrd1972's Avatar
So if at cold startup if one is 350 and the other one is already bouncing then they are bad right?
Old May 7, 2007 | 10:13 AM
stereomandan's Avatar
swap sides and see if the constant reading follows the sensor.
Dan
Old May 7, 2007 | 03:54 PM
96ZCamaro's Avatar
The o2 sensors are suppost to jump back and forth pretty much between .2 and .8 volts. If it constantly keeps going lower it means it is reading a bit lean, and if higher rich. But if one is just staying at the same # no matter what then yea I beleive that o2 would probly be bad.
Old May 7, 2007 | 07:33 PM
wrd1972's Avatar
My engine is missing due to arcing plug wires, does this cause the BLM to jump up?
Old May 7, 2007 | 07:57 PM
evilundisguised's Avatar
Yes, unused oxygen passing out of the cylinder and across the O2 sensor will be interpreted as a false lean condition. It is "corrected" by increasing the BLM.
Keenan
Jan 19, 2023 12:24 PM
QuickSilver02
Apr 7, 2015 11:12 AM
cmsmith
Mar 23, 2015 11:45 AM
captcorvette
Mar 7, 2015 12:37 PM
Jon657
Jul 19, 2002 07:51 PM
