Is this normal?
Old Aug 26, 2004 | 09:51 PM
ssbowtie1's Avatar
Is this normal?
When I start my car and run it with the oil fill cap off it runs fine with no smoke. I can take a folded piece of paper and put it on the oil fill tube and it won't fall. The paper will stick and no smoke exits at idle or revving (~3k or so).
When I turn the car off and look down the fill tube, light smoke comes out. Is this normal (extra crankcase pressure being relieved) or is this a problem? The engine does not smoke out of the fill cap when its running, just when the car turns off. Ideas/suggestions?
Old Aug 26, 2004 | 10:02 PM
lillbush5555's Avatar
Re: Is this normal?
try putting in a new PCV valve..It is the crank case vent and tends to get clogged.
Matt
Old Aug 26, 2004 | 10:29 PM
Re: Is this normal?
I don't see any problem with a little vapor coming out after you shut it off.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
