Noisy valve train
Old Apr 14, 2004 | 10:39 PM
agent z28's Avatar
Noisy valve train
I just converted to non-SA rockers with guideplates. There seems to be some valve train noise when the engine is under load. It sounds like a steady ticking. I don't think the rockers are too loose, but I could be wrong. The noise is audible inside the car and its really pissing me off. I adjusted the valves one cylinder at a time, setting the preload at 3/4 turn. The guideplates also appear to be properly aligned. Any suggestions on what I might have done wrong ?
Old Apr 14, 2004 | 10:41 PM
badblackta's Avatar
The non self aligning rockers are supposed to make more noise if Im not mistaken.
Old Apr 14, 2004 | 10:56 PM
Spinner's Avatar
SA rockers make more noise. Could just be injector ticking. 1.6 roller rockers will make much more noise then stock rockers, at any rate
Old Apr 14, 2004 | 11:11 PM
97WS6SCharged's Avatar
Also, you could be hearing noise from the lifters if you reused the stock ones. I'd say it's probably the rockers though, my new rockers (Comp Pro Mags, 1.6 NSA) are pretty noisy and they are spot on as far as adjustment.
Old Apr 15, 2004 | 01:13 AM
turbo_Z's Avatar
my NSA rockers make noise also and I only have 1/2 turn on the nut with stock lifters. They will just be loud... not much you can do about it besides getting some composite valve covers to help absorb some of the sound.
Old Apr 15, 2004 | 11:03 AM
BUBBA's Avatar
Do it again. Suggest you go 1/4- 1/2 on the preload. Assume that you have hardened push rods with the guide plates.
You shouldn't have too much noise, especially in the car. JMHO
Old Apr 15, 2004 | 08:51 PM
I wouldn't try 1/4 to 1/2 turn unless you've got a set of Comp R lifters, mine were loose at 1/2 turn with stock lifters, I reset them to 3/4 turn while the engine was running. Now everything is , except for the darn belts.
Old Apr 15, 2004 | 09:22 PM
agent z28's Avatar
Yeah, I've always read that the stock lifters require more of a preload than the heavy duty aftermarket units. I'm going to change the lifters as my next step. I'm still running the original stockers with over a 100K on them. I expected some increase in engine noise but something clearly sounds like its out of adjustment or very worn.
Old Apr 15, 2004 | 09:29 PM
What method did you use to set the valves?
Old Apr 15, 2004 | 09:52 PM
agent z28's Avatar
I used the third method listed on Shoebox's website. This is the method in which you adjust the valves one cyclinder at a time. I ran the adjusting nut down until it stopped, taking that point as zero lash, then I cranked the motor until the exhaust valve was in the correct position to adjust the intake valve in the same cyclinder. Then I performed the reverse as described in the directions. Maybe I didn't have the lifters on the heel of the camshaft lobes when I set zero lash. Could this cause the problem ?
Old Apr 15, 2004 | 10:10 PM
Ok, so you used the Exhaust Open Intake Close method? That's a very accurate way to get the valves setup to get the engine to fire up. Once it does, you really should adjust the valves with the motor running because the lifters won't really stay pumped up right otherwise.
Old Apr 15, 2004 | 10:13 PM
agent z28's Avatar
OK, I'll try to adjust the valves with the engine running.
Old Apr 15, 2004 | 10:16 PM
Just remember when you set the preload, turn the nuts 1/4 turn at a time and do it slowly or the lifters will bleed down.
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
