Noise
Old Feb 22, 2011 | 06:23 PM
chrisblanton's Avatar
Noise
On my 94 Z 28 I'm having some popping noise after installing pace setter long tube headers and pace setter y pipe. It sounds like the header is hitting the engine mount or y pipe is hitting under the car. has anyone else had any problems with this? Thanks for any and all advice
The car is lowered 1.2 inches. KYB fully adjustable shock/struts. Adjustable rear control arms and pan hard bar. Cold air intake. Pace setter long tube headers
Old Feb 23, 2011 | 04:43 AM
Guest47904's Avatar
Guest
Re: Noise
My Hookers hit underneath. Didn't see it until I put it on a lift. Had to make a 1/2 in notch to keep it from hitting.
Old Feb 23, 2011 | 10:16 AM
Z28SORR's Avatar
Re: Noise
Poly motor mounts might help.
Old Feb 23, 2011 | 05:52 PM
Re: Noise
Where did you make the notch?
Old Feb 25, 2011 | 05:33 AM
Guest47904's Avatar
Guest
Sometimes you just have to get dirty......
Can't remember but even if I did, would it matter? Where mine was hitting doesn't mean that's where yours is hitting.
This is a case of finding your own problem. If it's not obvious when you get under it to look at it. You have to pull and rock on it until you see where it hits. Then decide if you dimple the header (which is always a bad idea) or notch the frame/body.
Old Feb 26, 2011 | 08:00 AM
Re: Noise
i was just wondering so i had n idea cause i've pushed pulled rocked and everything on the exhaust and found nothing. only thing i found was a spot on the motor mount and put a piece of hose to stop that one put have another one some where just not sure and it's not obvious to the eyes
Old Feb 26, 2011 | 02:26 PM
94Camaro_Z_28's Avatar
Re: Noise
Mine hit until I put poly mounts on the motor.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
