Noid light best way to test PCM firing injectors ?
Old May 4, 2004 | 08:00 PM
Lt1t56's Avatar
Been dealing with a problem for a while now, suspecting PCM problem. Would noid light be best to check injector fire from PCM ??
Thankyou.
Old May 4, 2004 | 09:53 PM
HBHRacing's Avatar
personaly a test light workes better cause you can test each wire independently. should have constant key on hot on one side and a pulsing ground on the other.
AdsoYo
May 2, 2018 03:21 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
naaz90
Jul 27, 2002 08:22 AM
