No Tach or Speedometer
Old Apr 5, 2003 | 02:26 PM
red's Avatar
red
Question No Tach or Speedometer
I put my dash back in the car today and when I fire it up I have no Tach or Speedometer. All the other gagues and lights work fine. When I hook up LT1 edit and scan the computer I get a reading for both MPH and RPM. I can not find any fuses that are blown.
Does any one have any idea why my tach and speedometer does not work? Is there somthing else the tach and speedometer are hooked to on the car that will cause them to not work? For example, if a tail light goes out sometimes a light in your dash will go out also or if you horn does not work the cig lighter will not work.
Old Apr 6, 2003 | 12:18 PM
red's Avatar
red
TTT
Old Apr 6, 2003 | 02:05 PM
ponykiller z28's Avatar
pull your passenger side kick panel off and there's three harnesses in there: white, black, and blue. the white one is your guages. maybe it came loose
Old Apr 6, 2003 | 04:40 PM
red's Avatar
red
I will check that. Thanks.
Old Apr 6, 2003 | 08:02 PM
red's Avatar
red
I checked the plugs and everything was connected. Anyone have any other suggestions?
mr28
Apr 20, 2016 05:44 PM
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mobleman
Nov 13, 2002 12:05 AM
xkatodude
V6 Tech
Sep 21, 2002 08:53 AM
